The policy must exist before you can name it.
Assign a name to an existing access policy to uniquely identify the policy.
Assign a name to an access policy:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#access-policy 10 name useraccounts
The following table defines parameters for the access-policy command.
 Variable  |
 Value  |
 name WORD<0–15>  |
 Specifies a name expressed as a string from 0–15 characters.  |
